68 Vent Windows
Old Jul 9, 2006 | 08:30 PM
withoutcomp1's Avatar
withoutcomp1
Default 68 Vent Windows
Can anyone tell me if the vent window assembly from a 65 fastback are the same as a 68 fastback?
Old Jul 9, 2006 | 09:07 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: 68 Vent Windows
They are not but all vent windows from the same year will work. Coupe, fastback and convertible are all the same for 68.
Old Jul 9, 2006 | 09:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
Nope. 65-66 are the same, and 67-68 are the same.
Old Jul 9, 2006 | 09:49 PM
Shifty101Easy's Avatar
Shifty101Easy
on one of the little lock lever things is differnt than the other on my car...is that normal or is one of them wrong????
Old Jul 9, 2006 | 10:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
They should both be the same if you have the original year correct vent windows.
Old Jul 10, 2006 | 12:01 AM
67t5ponycoupe
65-66 same, same. 67-68 not the same as 65-66 or the same as each other. They will fit in but the latch for the vent is different and you can't just change the latch because the vent window its self is a little different.
Old Jul 10, 2006 | 12:41 AM
withoutcomp1
Thanks. Does anyone make a whole new assembly that i can buy? I found the frame new but nothing complete.
Old Jul 10, 2006 | 01:46 AM
67t5ponycoupe
Where did you find the frame? I've been looking and had not found anything. The only thing you will find fully assembled is used.
Old Jul 10, 2006 | 11:32 AM
withoutcomp1
I found them on ebay and also mustangs unlimited.
Old Jul 10, 2006 | 08:56 PM
67t5ponycoupe
Well I'll be dipped in dodo, there they are!
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
tmdm
Sep 4, 2015 06:45 PM
