289 swap
Old Jul 12, 2006 | 11:55 PM
bluelespaul's Avatar
bluelespaul
Default 289 swap
hi, i just joined and was looking for some info on swapping a 289 into my '66. i have a bunch of questions so i think ill jsut make a list.
1. how much am i looking to spend on the 289 and a new auto tranny(i dont want the 2 spd any more and i dont wanna convert to a manual)
2. how reliable would a new old engine be?
3. is it really worth the time and money to get the 289?
4. i would REALLY like to swap in a 302 from a '69 BOSS but ive heard that the biggest engine that will fit into the '66s is the 289, is this true and if so, how much cutting would i have to do to get the 302 in that little engine bay?
thanks in advance
Old Jul 13, 2006 | 12:04 AM
dodgestang's Avatar
dodgestang
Default RE: 289 swap
Alot, ask yourself this instead - "How much money do I have to spend"
Just fine, unless you build/buy a motor and ask it to do something it was built to do.
Depends, what you got now? What you want to do with it?
https://mustangforums.com/m_1627542/tm.htm
Ask and answer these:
What kinda car do I want? (daily driver street car, track only car, strip/street)
How much power do I want? (200 rwhp, 300rwhp, 400rwhp, 500rwhp, more?)
How much money do I have to spend?
All three should work together before opening your wallet.
For instance....
I want a daily driver street car with 500 RWHP and have $2,000 to spend obviously doesn't work
Old Jul 13, 2006 | 12:33 AM
428coupe's Avatar
428coupe
go to the FAQ section to find info on the 289 swap, I assume you have an inline 6 now right? give us more details about your car
Old Jul 13, 2006 | 12:39 AM
mustanglover66's Avatar
mustanglover66
As for the biggest engine you can put in there is the 351 but its tight. A 302 is the same size block as a 289 they are interchangeable and use the same motor mounts. the boss 302 is differnt though, I don't know in what exteral ways though.
Old Jul 13, 2006 | 11:19 AM
Color by WEASEL's Avatar
Color by WEASEL
I have actually seen 289 engine and C4 tranny's in the local trader for about 500 bucks. More than once. Way back in 1974 I had a 65 with a 6 and swapped out to a 289. Motor mounts were different but bolted up. To do it right, changing a 6 to an 8 is really more than just swapping the engine. You can do that but other issues are at stake. Suspension. 4 bolt wheels -vs- 5. Rear end, driveshaft, all considerations that Ford made different from one to the other for a reason. Torque, power, strength, all hand in hand. Good luck!
Old Jul 13, 2006 | 04:35 PM
bluelespaul
it seems like its alot more work than i thought.all i was after was around 350RWHP for around 2500$. oh well, what could i do to the I6 to give some more power, because ive heard that the I6`s are REALLY slow. i would know how fast it is but its not running now so i gotta wait a week or so untill i can feel for myself.
Old Jul 13, 2006 | 10:10 PM
fast66's Avatar
fast66
ORIGINAL: bluelespaul
Considering 350RWHP is about 440 crank HP, thats a pretty warm 289, and for $2500 for whole swap? No chance! Are you sure you need 350RWHP? a dead stock 289/302 4v will put a smile on you dial, and may come in closer to your $2500. (if you can find all the supporting brake/suspension part for next to nothing)
Old Jul 14, 2006 | 12:20 AM
Silver Ponys's Avatar
Silver Ponys
300 crank hp in my 05 puts a big grin on my face every time i drive it. I cant wait too see what 300 crank hp in my 65 which is a 1000 lbs lighter will do
Old Jul 14, 2006 | 03:14 AM
Smothers's Avatar
Smothers
It cost me about $1,400 to have my 289 rebuilt into HP engine, however I already had the carb and intake manifold. Have not had her on the dyno yet, but when I punch it getting on the freeway, it can make me sing opera style
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
