Voltage Drop
Old Jul 14, 2006 | 05:32 PM
jdforsythe's Avatar
jdforsythe
Default Voltage Drop
Hey Folks,
68 conv, 289 stock alternator. I get a siginificant voltage drop when idling. With headlights on, the turn signals will not blink. I expect a certain drop with all old cars, but what would you folks suggest for correcting this problem or should I just live with it?
Old Jul 14, 2006 | 05:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Voltage Drop
First, make sure the alternator and battery and voltage regulator are up to snuff. Have the alternator and battery checked at a parts place. Make sure all your connections are clean, and that the battery is rated at the right amount of amps for your car. If everything is up to snuff and it still has those symptoms, you might consider going from a 70 amp alternator to a 100 amp alternator.
Old Jul 14, 2006 | 05:49 PM
jdforsythe's Avatar
jdforsythe
Thanks for the info, how many amps should my battery be rated for?
Old Jul 14, 2006 | 05:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
835-925 cranking amps at 32 degrees Fareinheit.
Old Jul 14, 2006 | 06:28 PM
jdforsythe's Avatar
jdforsythe
Thanks again, the battery is rated at 625 amp at 32 degrees, it is relatively new and cranks great. Will the the low rating have that much of an impact? Is the electrical system drawing from the battery when the car is idling? Thanks again for all your, I am new to this forum
Old Jul 14, 2006 | 06:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
You need a bigger battery. Take your alternator to a parts place and have it tested. If it is putting out 70 amps, then you are OK if you don't have some power pulling stereo equipment.
jwog666
Dec 27, 2021 08:09 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
TfcCDR
Sep 14, 2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
