Air compressor replacement?
Old Jul 15, 2006 | 06:35 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default Air compressor replacement?
When driving back home from town today, my old York air conditioner compressor locked up. The poor old thing is 42 years old, so I guess it paid its' dues and is now ready for compressor heaven. Anyway, I have been pondering which compressor to replace it with, and everyone seems to think the Sanden is the cat's meow. I found one on Ebay. Take a look at it and tell me if you think it is a good price, and will it simply bolt on with the kit that comes with it.
http://cgi.ebay.com/ebaymotors/66-FO...05245893QQrdZ1
Old Jul 15, 2006 | 07:23 PM
hutchamatic's Avatar
hutchamatic
Default RE: Air compressor replacement?
I sell that compressor for 190 and the bracket for 55. The complete bracet set is a nicer way to go. With that adapter you will have to modify your tensioner bracket. Also need to change condenser for maximum cooling.
Old Jul 15, 2006 | 07:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
So, are you saying I can get the compressor and complete bracket set from you for $245 and I won't have to replace the original condensor?
Old Jul 15, 2006 | 07:36 PM
hutchamatic
The complete bracket set with tensioner and pulley is 106.00. I installed one last week and it is a really nice setup. I have used three of those York adapters and they work ok. There is some welding to be done to make your tensioner work. I would have to check on the hoses and drier. Drier should be about 30. Probably around 45 for the hoses. I would chaneg the condensor. R-12 and R134 condensor are completely different. R-134 has many more molecules that R12, thus requireing a different condensor. The R-12 is a tube and fin and the R-134 is a micro tube design.
Old Jul 15, 2006 | 07:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
OK, well I had the 134A conversion a few years back, and it blew plenty of cold air with the old condenser. So, I guess you are saying I need a whole new system. Is that right?
Old Jul 15, 2006 | 08:04 PM
hutchamatic
You can still use the Evap unit. They work good. I suppose your is the hang on unit? A complete Vintage Air sure fit kit is only $975 and you get lots of under dash room.
Old Jul 15, 2006 | 08:42 PM
Cannonball888's Avatar
Cannonball888
ORIGINAL: hutchamatic
Hutch, are you talking about this mount for the Sanden?
My '65 has a different compressor mount with bulit in tensioner bracket. I don't need it though, because tension can be adjusted with the tensioner on the power steering unit which runs off the same belt.
Old Jul 15, 2006 | 08:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, that's the same unit and bracket that's on Ebay.
Old Jul 17, 2006 | 01:37 PM
hutchamatic
I haven't seen a bracket setup like that. Where did that come from. And usually the PS belt and AC belt are different.
Old Jul 18, 2006 | 03:39 PM
hutchamatic
Here is a pic of my 390 setup.
[IMG]local://upfiles/23043/A398D4F144894911839349C297C14824.jpg[/IMG]
