Air compressor replacement?
ORIGINAL: hutchamatic
I sell that compressor for 190 and the bracket for 55. The complete bracet set is a nicer way to go. With that adapter you will have to modify your tensioner bracket. Also need to change condenser for maximum cooling.
Thanks
Texas Mustang has the Sanden kit with includes the new sanden compressor, bracket, hardware, new discharge and pressure hoses and new filter dryer. The cost for my 65 V8 is 388.00. For the 73 V8 it is 451.00
I haven't seen a bracket setup like that. Where did that come from. And usually the PS belt and AC belt are different.
I have just aquired a complete AC bracket setup for a 65-66. It does not have compressor but I can supply that. I will take 125 for the bracket and 185 for the compressor. It is not an adapter. It bolts to the head and water pump, Has the tensioner and crank pulley with it. Also has all bolts and spacers.
Sep 1, 2015 08:16 PM
HIS S-197
Aug 10, 2015 05:47 PM
