Pitman Arm Removal help
Old Jul 16, 2006 | 01:11 AM
Gun Jam's Avatar
Gun Jam
Default Pitman Arm Removal help
I am trying to remove the drag link and I got all the steering linkages free except the pitman arm. I am trying to free the drag link from the pitman arm it is connected to the stud that goes into the control valve. Everything else is free, my method of removal is : remove split pin from stud, remove bolt, hammer wedge fork between pitman arm and control valve. I got all the other linkages free this way but the last one wont budge.
I do not wish to remove the pitman arm from the steering box due to realignment issues.
My next move is to use a cutting torch and cut the pitman arm in half between the steering box and control valve stud.
Am i missing something, these things should come out with the wedge right and nothing else should be holding it?
The other linkages seemed to be held in the same way and did fight me but came free after a little battle. This dang thing won’t move what gives?
Gun
Old Jul 16, 2006 | 01:46 PM
mustanglover66's Avatar
mustanglover66
Default RE: Pitman Arm Removal help
you have to use a pitman arm puller the weage will only damage it. another posiblablity is a two arm puller.
Old Jul 16, 2006 | 02:27 PM
Gun Jam's Avatar
Gun Jam
It is just a press fit then Right?
Thanks for the advice
Gun
Old Jul 16, 2006 | 02:29 PM
428coupe's Avatar
428coupe
pitman arm puller is used to pull the pitman arm from the gearbox, he does not wish to do that.
I always use the fork too, have you tried to add heat to the drag link?
Old Jul 16, 2006 | 02:50 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: 428coupe
heat it and tap it with a mallet a few times. maybe it's just a little stuck and stubborn.
Old Jul 16, 2006 | 02:56 PM
Gun Jam's Avatar
Gun Jam
Yeah that’s a good idea I guess i should start there before I give up and cut it in half
Ill let you know how it goes
Thanks
Gun
Old Jul 16, 2006 | 05:29 PM
Gun Jam's Avatar
Gun Jam
Got it!
Didnt go as planned but its out, thanks for your help guys!
Gun
Old Jul 16, 2006 | 05:40 PM
RicM's Avatar
RicM
Clu7ch GOOD suggestion. Do you have a 65/66 if so whats your ride height?
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
