351w help
Old Jul 16, 2006 | 01:46 AM
Cleeman99's Avatar
Cleeman99
Default 351w help
Hi i got a 351 windsor for free from my grandpa it only has 145,+/- km but it outa 87 ford F-250 i need some help on just how i can get performance and fuel econmy. i want to know what i can put in it for a good camshaft one prob i dont kno how to get the compression ratio and then what else i could do to add power fairly reasonly priced other then NOS where i live it illegal but and help on telling me what i could make it push for RPM's i need as much as possible and one thing r the 351w and 351c tranmission bold up patteren to the block the same. any help much thx
any advice on what to do for stonger frame so dont twist and front suspenson to handle the waight from a v6 to 351w thx
Old Jul 16, 2006 | 02:10 AM
atomsk680's Avatar
atomsk680
Default RE: 351w help
kilometers? oook, i see your from canada, i dont know what 145km converts into miles. i did not know NOS is illegal in canada. anyway. what kind of car do you have? depending on the year you might have to do some work too the engine bay before you drop that 351 in. for a stronger frame, subframe connectors are good. you will have to upgrade the suspension, also the rear end and transmission to name a few others. look around in the FAQs for more info. there at the top of this forum list, not at the very top near the logo.
Old Jul 16, 2006 | 02:18 AM
Cleeman99's Avatar
Cleeman99
ya it 1986 ford mustang lx my dad said i should be able to drop my 351 in there np but do u know what i can do to change it from lots of pulling power over to high performance like cams and stuff
Old Jul 16, 2006 | 02:30 AM
atomsk680's Avatar
atomsk680
1986[8D] thats old but not quite to classic status yet. ask your question here https://mustangforums.com/forumid_14/tt.htm , they can help you more
EDIT: or did you mean 1968 and not 1986?
Old Jul 16, 2006 | 02:34 AM
Cleeman99's Avatar
Cleeman99
thx i meant 1986
Old Jul 16, 2006 | 02:38 AM
atomsk680's Avatar
atomsk680
ok then, the 5.0 guys will be of more help.
Old Jul 16, 2006 | 02:39 AM
myshifter's Avatar
myshifter
I ♥ Acer
the absolute biggest problem with stock 351's is the garbage cylinder head, you will be hard pressed to make any signifigant increase in power with that head. The most economical thing you can do is one of two things. Find a set of old D0OE heads or use a gt40 302 head and drill the bolt hole to 1/2 inch since 302's use a 7 1/6 head bolt. Thats what I would save my pennies for. Then you can step up the cam a bit, until then your not going anywhere
Old Jul 16, 2006 | 04:41 AM
deadcarnahans's Avatar
deadcarnahans
ORIGINAL: myshifter
I agree 90%. The heads have to go.
But the GT-40s and most aftermarket heads already have the 1/2" bolt holes. No reaming required.
I installed TFS heads on my 351W with a mild cam. Needless to say, I was quite happy until the clutch disc ripped apart.
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
FoxGT
Jul 11, 2004 11:49 PM
Mustang88LXKid
Feb 29, 2004 08:01 PM
WNDSOR
Jan 30, 2004 09:47 AM
