TUNE UP HELP
Old Jul 16, 2006 | 06:19 PM
randybobr's Avatar
randybobr
Default TUNE UP HELP
I tuned 1966 289 up today plugs,wires,fuel filter,rotor, distributor cap,points. When i finished the car ran fine for a few minutes then died. The owner said it had been stalling after being driven for awhile. What could it be. Coil?
Old Jul 16, 2006 | 06:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: TUNE UP HELP
Ask him when was the last time he had fresh gas in it. Sounds like a fuel related problem. so check the filters and whether or not the fuel pump is pumping properly, then move on to the carb.
Old Jul 16, 2006 | 07:02 PM
randybobr's Avatar
randybobr
But now it wont start at all. Thanks.
Old Jul 16, 2006 | 07:51 PM
fast66's Avatar
fast66
If its the coil, you will be getting a weak orange spark, rather than a strong blue one.
Old Jul 16, 2006 | 09:27 PM
Gun Jam's Avatar
Gun Jam
If the coil is weak heat may cause it to stop working.
Pull the boot off the top of the coil and place a metal object over the spot where the boot fits and have some one watch and see if spark jumps to the grounded piece of metal. If yes then probably not coil.
Did you use a clear fuel filter can you see fuel in it?
If you remove the fuel line from the carb and place it in a cup and crank it about 3 sec does it fill most of the cup? Does fuel come out of it at all?
Gun
Old Jul 16, 2006 | 10:45 PM
67t5ponycoupe's Avatar
67t5ponycoupe
If you changed the condensor put the old one back in and see if it helps.
Old Jul 17, 2006 | 04:20 AM
randybobr's Avatar
randybobr
Thanks for the responses i will check these thing out in the morning.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sixx
Oct 5, 2015 07:36 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Explosive
Oct 2, 2015 07:45 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
