Toasted engine
Old Jul 23, 2006 | 09:14 AM
daves67's Avatar
daves67
Default RE: Toasted engine
Tear it down and check for damage yourself.
Old Jul 23, 2006 | 12:06 PM
paladin_1888's Avatar
paladin_1888
check the engine numbers, if its the original A-code, pull the oil pan and take a look at the bearings[this can be done with the engine in place] if the bearings are bad and the crankshaft is ok, then pull the engine and do a rebuild. I would keep the engine if it isnt totally screwed. Would rather have an original A-code than most any replacement.. With a fresh quality rebuild you can have a good, reliable car again, maintaining the original flavor of a classic.
Old Jul 23, 2006 | 02:12 PM
green_blurr's Avatar
green_blurr
O k im checkin the engine for damage right now im gonna reply with what i find
Old Jul 23, 2006 | 06:36 PM
green_blurr
AHHHHHHHHHHHH [sm=smiley19.gif] there is radiator water in my cylinders i took off the manifold and it was a waterpark.... im too afraid to look any further i dont know what other damage has been done... or if there is water in the other 4 cylinders.. i dont know if its worth it too take off the oil pan and have a look should a scrap the engine?
Old Jul 23, 2006 | 06:42 PM
green_blurr
ok dang i forgot to drain the radiator fluid first... my bad im new to cars ok gonna look for blown gaskets
Old Jul 23, 2006 | 06:52 PM
Colorado_Mustang's Avatar
Colorado_Mustang
[sm=ttiwwp.gif]
Old Jul 23, 2006 | 07:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
Water in your oil and vice versa usually means a blown head gasket, but sometimes can be attributed to a cracked block. Tear down the top half of the engine and see if the head gasket is the culprit.
Old Jul 24, 2006 | 01:48 AM
green_blurr
i checked the dipstick the oil smells burnt really awefull stinky i was advised to get a new engine but the cylinder walls and pistons look good prolly need to be ported and polished and new gaskets other than that i dont know...
Old Jul 24, 2006 | 02:10 AM
green_blurr
I cant get the pics of my car to load on this post but EVERYONE LOOK IN IN PHOTO ALBUM TO GET AN IDEA!!
Old Jul 24, 2006 | 02:11 AM
green_blurr
I cant get the images to load on this forum but EVERYONE LOOK IN MY PHOTO ABULM TO GET AN IDEA
