351w or 352
Old Jul 23, 2006 | 03:54 AM
hutchamatic's Avatar
hutchamatic
Default RE: 351w or 352
Do any of yall know what FE stands for. This could be a good trivia question. I do so I am not asking for myself, just curious how many people really know.
Old Jul 23, 2006 | 05:03 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
my guess is either the Ford-Edsel like i have heard or FE the element in whitch it is made out of
Old Jul 23, 2006 | 05:18 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Ford Engine.
ORIGINAL: hutchamatic
The 352FE and the 351W have identical bore and stroke. The only difference will be in the flow of the heads. The FE will not necessarily make more power just because it's a big block, there's a lot more to the equation than the physical size of the block.
Which engine you drop in the '70 should depend more on which style was there to begin with. If it's an original FE car, then you've already got the necessary hardware for the FE. If it was a Windsor car, ditto. Personally, I'd rather build the 351W than the 352FE, unless I had access to a 390/427/428 rotating assembly....
Old Jul 23, 2006 | 02:23 PM
Twister's Avatar
Twister
ok, here is the simple truth, I can't give away a good 352! Use the 351W
Old Jul 23, 2006 | 02:25 PM
69FECoupe's Avatar
69FECoupe
There's a liiiiiittle more different than just the headlights.
Old Jul 23, 2006 | 03:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Colorado_Mustang
Ford Engine.
Whether FE means Ford Edsel, or Ford Engine has been an argument for decades. I have not read where either one has been determined positively. Personally, I will go with Ford Engine.
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
hmcnab
Apr 6, 2004 07:27 PM
Mustang88LXKid
Feb 29, 2004 08:01 PM
WNDSOR
Jan 30, 2004 09:47 AM
