i need help quik!!!!!
Old Jul 24, 2006 | 02:50 PM
6fivestang's Avatar
6fivestang
Default i need help quik!!!!!
ok, i cant get my car to start right now and i need to go to work.i turn the key and nothing happens. what can i check?
Old Jul 24, 2006 | 02:54 PM
Cannonball888's Avatar
Cannonball888
Default RE: i need help quik!!!!!
No sound at all? Could be the solenoid. Push the horn. Anything? If no horn then dead battery. If horn sounds then I'd say solenoid and you can jump the terminals. If battery then you (and a friend) can push start it if a manual tranny. Good luck.
Old Jul 24, 2006 | 02:57 PM
Derf00's Avatar
Derf00
Gentleman's Relish
If it does nothing as in no click or anything, check your battery connections both at the battery, the solenoid connections on the firewall, and finally your ground wires.
6fivestang's Avatar
6fivestang
horn works. but still wont start. i think im gonna take the day off to fix this. what do i need to buy/repair?
Old Jul 24, 2006 | 03:04 PM
Derf00's Avatar
Derf00
Gentleman's Relish
probably a starter solenoid then. Quick way to test that is to do what CanonBall suggested. Short across the two copper terminals on the solenoid and see if it starts up. If it does. Replace the solenoid. $10-13 at teh local auto parts store.
Use a plastic handled screwdriver and do NOT touch the car when you touch the screwdriver to both terminals.
Quik
Jun 14, 2007 01:59 AM
highskewlmustnglvr86
Nov 8, 2006 09:11 AM
Black Snake
Mustang Videos
Apr 5, 2006 03:53 PM
83beast
Sep 30, 2005 12:37 PM
