window thingy
Old Jul 27, 2006 | 07:54 PM
angus18's Avatar
angus18
Default window thingy
i have a 65 and my window notch thingy is like rusted out so i bought a new one and i just got off my door panel...now where do i put my new window crank thingy?? i know where the old one is but i dont know how to get it off do i have to get my door metal out of the door or what
Old Jul 27, 2006 | 07:58 PM
Gun Jam's Avatar
Gun Jam
Default RE: window thingy
I dont totaly understand the problem but to get the window crank off just rotate it 180 degrees and you will see a set screw on the bottom of it. just undo that set screw
Gun
Old Jul 27, 2006 | 07:59 PM
angus18's Avatar
angus18
ok i want to replace the window regulator do i have to take the shell off the door to get to it??
Old Jul 27, 2006 | 08:00 PM
Shifty101Easy's Avatar
Shifty101Easy
no, there should be access holes once u take off the door panel......it might not seem like it can come out through there but it definitely can......u have to unbolt it too.....
Old Jul 27, 2006 | 08:01 PM
Gun Jam's Avatar
Gun Jam
a window regulator? Ugh got me I dont have a clue???
Hope someone else can help
Gun
Old Jul 27, 2006 | 08:05 PM
paladin_1888's Avatar
paladin_1888
you have to remove door handle and window crank and door panel , if its an early 65 it may have c-clips holding the handles instead of set screws. these are removed with a window handle tool, bout $6. from advance or auto zone, also get an upholstery removal tool, looks like a screwdriver with a crow foot on the bottom.This is used to pry the holding clips from the door without tearing up the door panel
Old Jul 27, 2006 | 08:06 PM
angus18's Avatar
angus18
ok i did that...now how do i reach the window regulator....
Old Jul 27, 2006 | 08:11 PM
paladin_1888
window regulator is held in by 2 or 3, bolts, remove the bolts, but take care to keep the window in place, with the reg out it will fall to the bottom like a rock, once the bolts are out there is a small clip holding the reg to the spider arm. remove clip then just take the reg out and replace
Old Jul 27, 2006 | 08:28 PM
angus18's Avatar
angus18
i know what your saying but i cant get into it because of the shell or the thing underneath the door panel....
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
mungodrums
Sep 22, 2015 08:36 PM
wishinsky
Sep 21, 2015 09:48 AM
