Can't find switch
Old Jul 30, 2006 | 05:47 PM
Lawshe's Avatar
Lawshe
Default Can't find switch
I have a 1966 Mustang with a 289 engine and automatic shift. My Park/Neutral Safety Switch is intermittent and I need to know how to access it so I can change the switch. Your help is appreciated.
Lawshe
Old Jul 30, 2006 | 07:49 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Can't find switch
It is on the transmission where the linkage goes throught the case.
67t5ponycoupe
Might just need adjustment
Old Jul 31, 2006 | 06:07 PM
ebluekeys's Avatar
ebluekeys
Yeah, the mounting holes are sort slotted, so you have a couple degrees of adjustment range. They are easy enough to take off, just be careful not to FORCE the "drop down" shift lever that goes through the middle of the shaft. I just changed one cause the backup lights wouldn't work, and shorting the pins on the plug on front of the firewall lit them up. Any of the mustang catalogs carry the item. It's in the 30 to 40 dollar range.
mtgldr
Feb 3, 2024 09:00 PM
2007CalSpec
Dec 13, 2020 11:42 AM
Wombatnation
Sep 13, 2015 09:16 PM
whatsup62
Sep 3, 2015 01:38 PM
