Headliner help
Old Jul 31, 2006 | 11:15 PM
baddog671's Avatar
baddog671
Default Headliner help
Im going to prep my ceiling surface and then lay down some Dynamat. When I get the headliner down, will it be able to go on that, or will it need the fluffy insulation to stick to?
Old Aug 1, 2006 | 03:33 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Headliner help
Dynamat needs to go on the metal or is not going to do much good.
Old Aug 1, 2006 | 03:43 AM
Twister's Avatar
Twister
if you are doing a coupe, pay a pro...I have done a few headliners in my time, and a coupe is a major PITA
Old Aug 1, 2006 | 04:48 AM
Shifty101Easy's Avatar
Shifty101Easy
how much is it generally to pay a pro?
Old Aug 1, 2006 | 01:14 PM
coda618's Avatar
coda618
The dynamat will be fine. You do not need loose fibergalss insulation. The headliner does not stick to the roof. Adhesive is only applied at the edges where it folds over the door frame under the windlace and where it folds over the front a rear window frames. Yes, the correct way to install on a classic mustang is to remove the front and rear windows. However, it can be done without.
Good luck
Old Aug 1, 2006 | 10:05 PM
baddog671's Avatar
baddog671
ok thanks. I realize I didnt explain it well. I wasnt sure if the headliner needed the fluffy stuff to hold onto or not.
Roger Mabry
Jun 15, 2016 08:27 AM
MonsterBilly
Sep 19, 2015 08:50 PM
yurizx6r
Aug 24, 2015 05:48 AM
mrsoup
Sep 17, 2004 04:05 AM
uppy
Nov 3, 2003 07:48 PM
