Removing Fenders
Old Aug 3, 2006 | 05:00 AM
Shifty101Easy's Avatar
Shifty101Easy
Default Removing Fenders
to take off the fenders on my 68 do i have to remove the headlamp buckets or anything???
Old Aug 3, 2006 | 10:25 AM
baddog671's Avatar
baddog671
Default RE: Removing Fenders
No, should be the same as my 67. Take the fender botls off the top and I beleive 2 on the underside and it should just lift off. Mind you, you may have to work it alittle, mine seems to need pulled out, then up.
Old Aug 3, 2006 | 11:58 AM
valley firearms's Avatar
valley firearms
Also, open the door and just above the hinge you will see another bolt. There are numerous small bolts bolting the valance to the fender. It is easier to take off the bumper also. Unplug the headlight and running light. You cannot remove the headlamp bucket unless you have the fender off, even then it is a b!tch. Figure at least 1/2-1 hour perside for removal. You will get dirt in your eyes when trying to get the lower bolts so wear safety glasses. Good luck.
Old Aug 3, 2006 | 06:09 PM
coda618's Avatar
coda618
There is a bolt in the door jamb, as mentioned, A bolt under the rear lower part of the fender, two bolds to the radiator suppor, bolts running along the tops and also, you must detach the headlight bucket from the valance and upper stone guard. Be careful removing these as the buckets are pot metal and bend and crack very easily. If the bolt hangs up, do not force it, get some penetrant on there and let it soak in good, or you will wind up havin to replace the bucket.
Good luck.
Old Aug 3, 2006 | 09:46 PM
baddog671's Avatar
baddog671
Dont mean to steal the post, but while we're on it, does anyone know what that metal piece is behind the bucket? I think it keeps mud from being slung up in there. Thats the only rusted peice on my car that I need to replace, but I left it on there...
Old Aug 4, 2006 | 02:04 AM
valley firearms
That is your splash shield. It should have a piece of rubber fastened onto it. The other side of the rubber glues to the inside of the fender.
ORIGINAL: baddog671
Old Aug 4, 2006 | 03:41 PM
coda618's Avatar
coda618
i think he might be asking about the secondary bucket (for lack of a better name) that is an integral part of the fender. This ads suppot yo the fender by providing a mounting point to the radiator support and also ads structural integrity to the fender. It soes also serve to keep gunk out of the headlicht bucket. The splach shield mount to this part.
Old Aug 5, 2006 | 12:14 AM
baddog671's Avatar
baddog671
yes i think thats what it is ^...ill have to snap a pic of it to be positive, but its in very bad condition
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
zachary1988
Sep 18, 2015 11:17 PM
