Coil
Okay...I know virtually nothing about coils so any info is good. Since they're fairly cheap and I had to take mine off anyways, should I buy a new one? What exactly should I look for and what are the advantages of the new ones? Also, are there any additional parts I would need to buy?
I wouldn't worry about a new coil until you upgrade the engine or the old one goes bad. Then, go aftermarket. What you get will depend on your modifications. I generally run Accel Super Coils, but they are not easy to locate inside some engine bays, and definitely don't look original. Accel and MSD also make some chrome coils that are good for stockish engines and add a little shine.
ORIGINAL: Gun Jam
if its the 45k Volt then more voltage. but probably wont do you much good unless you have 8.5 - 9mm wire
Gun
Gun
ORIGINAL: ideal_mustangs
Just stick the original back on there if you just have a stock engine. My car still has the original 38 year old yellow top coil that still works great
