Coil
Old Aug 4, 2006 | 07:13 PM
jrrhd73must's Avatar
jrrhd73must
Default RE: Coil
The stock coil puts out some where on the order of 17k volts. If you are running points the best that is going to get to the engine is 12k or so. You would be better off with an electronic drop in like a pertornix or something if you are still running points.
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Coil
Just keep running your old one for now. If and when you upgrade your ignition system to electronic, then dedide which coil you will need. For instance, if you upgrade to the pertronix Ignitor II system, then you would also need to get the Ignitor II coil if you want a hotter coil. No sense in getting a hotter coil now and risk burning up your points.
Old Aug 8, 2006 | 03:14 PM
ad1997's Avatar
ad1997
Default RE: Coil
i took my old coil to autozone and they said they dont test them is their a way to test coils?
Old Aug 8, 2006 | 03:29 PM
67Sally's Avatar
67Sally
Default RE: Coil
ORIGINAL: ad1997
Coils basically last forever so you're probably okay.
Old Aug 8, 2006 | 03:53 PM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: Coil
Yeah man, It's just a coil. Not that big of deal. Stick in on and if it runs its good, if it don't its not good
Old Aug 8, 2006 | 03:55 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Coil
make sure you don't need resistor
Old Aug 8, 2006 | 04:07 PM
Twister's Avatar
Twister
Default RE: Coil
here's a trick to look stock...go with a Pertronix ignition kit and get a black coil....Krylon school bus yellow is a 98% match to the origional color!
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
firehorse02
Nov 16, 2015 11:28 AM
Sixer4Life
Sep 28, 2015 07:05 AM
lmurf60
Sep 24, 2015 10:07 PM
