1965 2+2 Fastback
Old Aug 4, 2006 | 11:16 PM
dhustler's Avatar
dhustler
Default 1965 2+2 Fastback
I am suppose to go to look at a 1965 2+2 fastback in couple of days that supposedly has a factory original 289. I want to know how to quickly determine via either the VIN or the engine marking how to tell if the 289 could be an "A" code "Hi-Po". Please advise as I own a 1969 Mach1 and I am not that familiar with pre 1967 mustangs.
Old Aug 4, 2006 | 11:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 1965 2+2 Fastback
Just check the VIN on the inner fender on the driver' s side of the engine compartment. The engine code will be the 5th digit.
T= inline 6 cylinder
C= 289 2v-200 HP
A = 289 4V - 221Hp
K = 289 4v - High performance (HiPo) 271Hp
Of course, the engine could have been changed out. Pull the starter and get the block code from there. Pull the valve cover and see if there is a stamping in the valley.
Old Aug 4, 2006 | 11:35 PM
67Sally's Avatar
67Sally
ORIGINAL: Soaring
C= 289 2v-200 HP
A = 289 4V - 221Hp
K = 289 4v - 271Hp
I think he's asking how to make sure that the engine is in fact what the VIN says it was.
Old Aug 5, 2006 | 02:16 AM
want_66fastback's Avatar
want_66fastback
Thats a TOUGH one...it is hard to tell if the engine is an "A" code or a "T" code...You can tell if the engine is a "K" code or not...alot of factors involving a "K" code...
Old Aug 5, 2006 | 09:59 AM
Soaring's Avatar
Soaring
I ♥ Acer
Well, it is easy to tell a T code from a C, A or K because a T code is a 6 banger. The C code has a 2V carb, and the A and K codes have 4 barrels. If it has a 4 barrel carb, it will probably be an A code engine because the K codes are pretty rare. However, if you have time to look at the engine carefully, here is how you can tell if it is a hipo K code.
https://mustangforums.com/m_766107/tm.htm
Old Aug 5, 2006 | 02:55 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
k code blocks are stamped with a partial vin regula a,c codes are not
Old Aug 7, 2006 | 10:25 AM
dhustler's Avatar
dhustler
Thanks all to responded. I thought A-Code was Hi-Po but now I know I should be looking for "K" code. Either would be good!
Old Aug 7, 2006 | 06:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: dhustler
If you stumble onto a K code engine for sale, you will be very, very lucky. But if you actually want to buy it, you best have a wheel barrow full of big money.
poke68
Dec 16, 2025 03:36 PM
Sep 24, 2015 09:18 PM
Sep 22, 2015 12:35 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Sep 10, 2015 08:39 PM
