Steering Wheel Puller or Socket (photo) ?
Old Aug 5, 2006 | 12:12 AM
Toddman0025's Avatar
Toddman0025
Default Steering Wheel Puller or Socket (photo) ?
I'm trying to get in and replace my turn signal cam and switch - there was an aftermarket steering wheel that wasn't hard to remove but I'm wondering if I will need a steering wheel puller to get this last nut off or will a large socket work? I've never used a steering wheel puller and was wondering if that's what it's for or just getting the wheel off initially. I gotta go buy a larger socket set than what I have anyway...
Old Aug 5, 2006 | 12:17 AM
67Sally's Avatar
67Sally
Default RE: Steering Wheel Puller or Socket (photo) ?
Just give it a shot with the socket. I think that will work.
Old Aug 5, 2006 | 12:18 AM
Cannonball888's Avatar
Cannonball888
You don't use a puller to take the nut off. If you don't find a socket big enough, a pair of large channel lock pliers will work.
Old Aug 5, 2006 | 12:19 AM
Toddman0025
ORIGINAL: Cannonball888
That's what I figured but just thought I'd ask before going out and wasting money on one.
Thanks for the help this forum is a great resource!
Old Aug 5, 2006 | 12:21 AM
Riven02's Avatar
Riven02
AHH man plz dont use pliers, it will just tear the hell out of the hex and make it look like crap. If you dont have a socket buy a socket. There is no reason to put gouge marks in the nut and risk roudning it off.
Old Aug 5, 2006 | 12:22 AM
Cannonball888
But you're going to need a puller for removing the rest of it. Some auto parts stores rent them cheap. Harbor Freight sells them cheap. So does NPD.
Old Aug 5, 2006 | 12:56 AM
paladin_1888's Avatar
paladin_1888
The nut has to come off first then use the puller to remove the plate under it, that what the threaded holes in the plate are for, attaching the puller bolts, then the center bolt of the puller goes down to the shaft in center. turn the center bolt till the plate puls off.
Old Aug 5, 2006 | 01:21 AM
Soaring's Avatar
Soaring
I ♥ Acer
Then there is the shade tree mechanic method. Get a big baseball bat and whack the crap out of it from the backside . Or, go get bubba and have him wrestle it off.
Old Aug 5, 2006 | 03:52 AM
Cogtx's Avatar
Cogtx
I think you might need a 15/16" socket for that hex nut. Purchase a wheel puller at Autozone or your auto parts place of choice for around $13. Get the one with configuration for at least 3 bolts like the one in the link below. I originally purchased the 2 bolt one to pull my wheel but needed the three bolt with an aftermarket steering wheel...
http://www.sealey.co.uk/images/products/PS975.jpg
Old Aug 5, 2006 | 09:52 PM
Toddman0025
OK got the nut off and the trim ring - now I need a puller for this part?
