Door removal?
Old Aug 10, 2006 | 03:12 PM
baddog671's Avatar
baddog671
Default Door removal?
Im thinking of removing my doors so I can paint the area around the hinges and inspect for rust, although I dont think there is any. How heavy do you think a full door is, should i do this myself?
Old Aug 10, 2006 | 03:18 PM
428coupe's Avatar
428coupe
Default RE: Door removal?
If your front fenders are off, you can leave the door closed and remove the hinge bolts going into the body, and then lift the door off alone. It is fairly heavy (and bulky), I would guess 70 pounds. If the front fenders are on, the door needs to be opened to remove it and that would be much easier with another person.
Old Aug 10, 2006 | 03:21 PM
Twister's Avatar
Twister
it is MUCH easier if you have a door jack!
Old Aug 10, 2006 | 03:33 PM
baddog671's Avatar
baddog671
Fenders are off. I was working on the front end and I'm continueing backward, so thats why im considering removing the doors. It looked like all I had to do was remove the 6 hinge bolts, is that right? Will there be any problems with it lining up right again, or should it be the same? Heres a pic...
Most of the front was good etching primer, you can see where I had to stop at the doors..
Old Aug 10, 2006 | 04:12 PM
428coupe's Avatar
428coupe
Yep, just 6 bolts, and yes it will need lined back up, but its not hard to do.
Old Aug 10, 2006 | 04:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
Get somebody to help you for about 5 minutes. Take the hinge bolts out and you are done with taking the doors off. You will have to spend some time aligning it after you put the doors back on, so do that before you put the fenders on.
jerrytubes
Oct 23, 2015 12:11 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
