finally started
Old Aug 12, 2006 | 12:26 AM
slick66stang's Avatar
slick66stang
Default finally started
today i put the first coat of fiberglass on my door. it turned out pretty good for it being my first time using matte. i grinded all the bad metal off and sanded the rust and door skin to bare metal. i thought it was going to be harder than i thought.
Old Aug 12, 2006 | 03:08 AM
baddog671's Avatar
baddog671
Default RE: finally started
Fiberglass should cure as hard as glass(der!), if it is slightly gooey or even wet looking but not gooey, you either used too little hardener or it was way too cold in the area u did it in. Id have to say the first since its summer...
Old Aug 12, 2006 | 03:17 AM
slick66stang
thanks nic. its rock hard. the whole bottom of the door skin was rusted out. now i cant bend the metal around the fiberglass. how many layers do i need to put on?
Old Aug 12, 2006 | 07:12 PM
baddog671's Avatar
baddog671
Do what you think feels secure.If I was u I would lay a thick layer, smooth it down, then 2 thin layer and fine grit paper to level it. Then for security, I would turn it over and put a big blob of resin on the back side of the metal to help from pulling out...
Pics!
2007StangV6
Jan 28, 2016 06:09 PM
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
5.0 kevo
Sep 3, 2015 06:24 PM
