289 fuel problems
Old Aug 12, 2006 | 09:24 PM
65Pony's Avatar
65Pony
Default 289 fuel problems
My 65 mustangs 289 is having problems getting fuel to the carb, I replaced the fuel pump and put a generic $15 fuel filter RIGHT before it pumps into the carb. The car will drive fine for a few miles but I get poor acceleration and it sputters and shuts down after a whyle. The fuel will barely squirt into the filter at idle most of the time. Lots of bits of crud and rust have accumulated in the filter and ive used it very little since I installed it to fix the problem.
I bypassed the fuel line and tank with a little red gas can and tube which runs straight to the pump. the filter was steady at 1/2 full of fuel the whole time at idle, even when I would accelerate the engine real hard. I think the Gas tank is full of rust from sitting so long and bits of rust got in the fuel line and cloged it up, could it be something else? any suggestions?
Im planning on buying a length of hose tomarrow and connecting that from the tank to the pump to see if it acts any different.
Old Aug 12, 2006 | 09:30 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 289 fuel problems
I had a rust ball in the line between the pump and carb on my '65. Compressed air is your friend when looking for clogs...
Old Aug 12, 2006 | 09:36 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Might want to pull the sending/pickup unit out of the tank and see what it looks like. Sounds like crud in the tank and/or the line.
Old Aug 12, 2006 | 09:52 PM
65Pony's Avatar
65Pony
Colorado did you clear the clog with compressed air blast?
Old Aug 12, 2006 | 10:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I would guess there is rust in the tank, and in the line. Compressed air is the best way to clear out the rust in the lines, but you must first repair the problem. You may need a new tank, a new sending unit, and new lines that lead up to the carb. Use your common sense.
Old Aug 13, 2006 | 01:50 AM
65Pony's Avatar
65Pony
Yeah I figured if theres cancer in the line then the origin must be the tank, I have a spare and im gonna put it and the line in tomarrow. I just wanted a quick fix to get it down the road today, and I didnt wanna use bailing wire and duck tape
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
