Noisy clutch return spring under dash.....
Old Aug 14, 2006 | 12:15 AM
Aux289's Avatar
Aux289
Default Noisy clutch return spring under dash.....
Anyone have any tricks or ideas on how to quiet the return spring? Should I just get a new one, or will they be "noisy" as well? I am running the stock 4 speed with the z-bar linkage, so I am assuming I need to keep the return spring.
Thanks for any and all help.
Mike
Old Aug 14, 2006 | 12:29 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Noisy clutch return spring under dash.....
A couple of these should do it up! http://www.mustangsunlimited.com/ite...atkey=emustang
Old Aug 14, 2006 | 12:30 AM
67t5ponycoupe
That is actually not a return spring that is an assist spring. Without it your clutch pedal will be very hard to push!
Old Aug 14, 2006 | 08:48 PM
Aux289's Avatar
Aux289
Thank you very much for responding 67t5ponycoupe. You got the best of my curiosity, so I went underneath the dash today to see how the heck it could be an assist spring. Now I see how it is, and I also found my noise. I sprayed some silicon lubricant on the spring where it connects to the clutch pedal, and the noise is gone. It is now quiet as a church mouse............and speaking of mice, please check out my other post about mice!
Mike
Old Aug 14, 2006 | 08:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
I find it amazing how many guys would use WD40 to quiten it down. Good choice on the silicone spray. Now, unless you are Goliath, I would not take that spring off to add any padding. Been there, done that.
Old Aug 14, 2006 | 09:38 PM
67t5ponycoupe
Those springs are not that hard to take on and off. The trick is to diconnect your equalizer bar and do it with the clutch pedal on the floor. Sorry about your luck with the mice. Bet ya $10 you ain't found them all!
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
mungodrums
Sep 28, 2015 10:54 PM
junior04
Sep 28, 2015 10:53 AM
