9 Inch Build-Up Help
Old Aug 14, 2006 | 04:30 PM
BlackFlame's Avatar
BlackFlame
Default 9 Inch Build-Up Help
Hi All--I need some help. Is there anybody out there currently building a 9-Inch Rear end for their machine? Im hoping that someone has a housing and a center section (that's still put together with the ring and pinion and diff in it), thats all out of the car. I dont need parts or pictures, I really only need measurements.
Its a long story why I need these, Im just trying to get axles so I can roll the car around, instead of staring at it on jack stands. Id would rather get the right axles now, that buy a mis-fitting pair only to get rid of them down the line.
Ive attatched a picture, and I only need the exact measurements of F, G and E. From those I should be able to determine, what measurements I need for axles. Either that or I need to borrow a center section for a measure up. HA[8D]
Any info would be greatly greatly apreciated! Thanks!
[IMG]local://upfiles/27743/DEA790D2B2B7418A9196E9EAF75662B5.gif[/IMG]
Old Aug 14, 2006 | 05:15 PM
jrrhd73must's Avatar
jrrhd73must
Default RE: 9 Inch Build-Up Help
We need to know for what year. There are slight differences in the measurements depending on the year. Also, if you plan on going with a wider tire, you might consider that now.
Old Aug 14, 2006 | 05:51 PM
BlackFlame's Avatar
BlackFlame
Alrighty--Should have given that info, sorry. Its a 68 mustang and Im using a housing that has an E measurement(according to my attatched post pic) of 52 + 7/16 inches. Its a small bearing housing--Im planning on running a 3.89/1 Gear Set, with a Detroit Tru Trac locker. T
he rear housing is NOT stock from the car, but I believe that the 67-70 rear was 52" or extremely close to that. As far as Wider Wheels, Im waiting to have the axles made up, So I can install those with the disc brakes to measure for exact backspacing! Thanks !!!
Thunderball
15
Nov 22, 2015 11:49 PM
jrrhd73must
Oct 2, 2015 09:17 PM
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Sep 28, 2015 05:45 AM
