dual point or electronic?
Old Aug 16, 2006 | 06:49 PM
JayStang65's Avatar
JayStang65
Default dual point or electronic?
got a 65' w/ 289 hi-po got it with a mallory dual point distributor and some after talkin to some buds they suggested a msd electronic distributor i was just lookin for some other opinions. thanx
Old Aug 16, 2006 | 07:06 PM
jdforsythe's Avatar
jdforsythe
Default RE: dual point or electronic?
I have a 289 a with single point distributor. I wrestled with EI but i finally bit the bullet and installed a Pertronix Ignitor II system. I got it from NPD here in Michigan. This system has the electronic module under the distributor cap so it still looks like my ignition system is stock. I had to buy a new coil with it. It was super simple to install and I have noticed that my car idles a little smoother and accelerates a little crisper. I mainly did it for ease of maintenance. I have no experience with the systems where you replace the entire distributor. However my distributor was working fine and I did not want to spend the extra money. Good Luck.
Old Aug 16, 2006 | 08:15 PM
Scott H.'s Avatar
Scott H.
Weekend show car. Polish that Mallory. It's totally old school. For drivabilty and lack of maintenance, go Electronic.
For the best of both, I read an article about 5 years ago where they converted the Mallory to a single trigger electronic.
You might try a search on Google to see if the info is available on the web.
Good luck.
BTW: Did you get the advance key with it? If so, you need to put it on your key ring. Old school folk will then know you're a super tuning gear head. Everyone else will ask what it's for.
Old Aug 17, 2006 | 09:39 PM
fredjchavez's Avatar
fredjchavez
Go Electronic...dont waste your time with points!
Fred
Old Aug 17, 2006 | 10:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: fredjchavez
Fred
Agreed. If you want to look old school original, get the Pertronix.
Old Aug 18, 2006 | 01:23 AM
Colorado_Mustang's Avatar
Colorado_Mustang
All you need is an MSD 6AL box to go along with your current dizzy. You'll need to disable the secondary points, but the primary points will be sufficient to trigger the MSD box. Make sure you have a good high rpm set of points to prevent mistriggers at high rpm.
Old Aug 18, 2006 | 02:48 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
the Crane XR-i is nice too it fits under the dist but it is sensative to heat in my experience and its basically a modified GM HEI Module
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
flash_xx
Oct 16, 2015 07:23 AM
folivier
Oct 2, 2015 05:34 AM
