Got her back from alignment shop..WOW
Old Aug 17, 2006 | 08:26 PM
skiprCH's Avatar
skiprCH
Default Got her back from alignment shop..WOW
Hi all!
I got my stang back from getting the front end worked on. They replaced all the tie rods and idler arm. I had the upper and lower ball joints replaced a while ago. I had also put a larger GT sway bar in it over the winter. I can't believe how responsive she is!! I had also found out that my car, even though not a GT, had the Special Handling Package. That means it has the GT suspension. The only thing missing was the larger sway bar. I'm not sure why it was not on the car. She had been in a wreck and it maybe got replaced with the smaller one then. Not sure but I tracked a larger one down and it really made a difference. I had also added KYB Gas Adjust shocks when I did the sway bar. All together she handles GREAT!
Walt
[IMG]local://upfiles/18678/AF20188133004F06BD4B049EA7191B42.jpg[/IMG]
Old Aug 17, 2006 | 08:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Got her back from alignment shop..WOW
Ain't if fun to finish a project and it works? Did you use the 1" anti-sway bar? How about the rear? Do you have an anti-sway bar back there? If not, then that is your next purchase.
Old Aug 17, 2006 | 09:00 PM
dawtips's Avatar
dawtips
no kidding, I really love my new suspension too, I couldn't believe the difference. Now to get my subframe connectors welded in, then after that I will put the rear sway bar on.
Tivo304
Aug 28, 2023 12:19 PM
Nick Oliver
Oct 17, 2018 04:22 AM
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Sep 1, 2015 08:16 PM
