Body cleanup.....
Old Aug 22, 2006 | 01:11 AM
jarrettdad's Avatar
jarrettdad
Default Body cleanup.....
I have just received my 67 Fastback S Code. It is a bit of a basket case, the previous owner had replaced the floor pans, but didn't prime them and left the car in the open. He did the same with the front fender aprons. Now they are suffering from a bad case of surface rust. I am going to clean them up with a wire wheel or something.... but afterwards, what kind of primer should I use? If I use a good Spray can primer will it cause my body shop any problems later? Any help will be appreciated......
Old Aug 22, 2006 | 02:05 AM
4reboy's Avatar
4reboy
Default RE: Body cleanup.....
I would spray it with self-etching primer that will really, really help any rust from coming back. ever.
Old Aug 22, 2006 | 02:47 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
por 15
Old Aug 22, 2006 | 04:29 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, you need to use a rust encapsulator such as POR 15, then a good coat of color.
Old Aug 22, 2006 | 09:14 AM
jarrettdad's Avatar
jarrettdad
Can I use a hvlp gun to spray POR 15?
Old Aug 22, 2006 | 02:37 PM
coda618's Avatar
coda618
por 15 can be sprayed. Read can for instructions. To help get rid of the rust, try some phosphate plus, or similar metal prep solution.
Good luck.
Old Aug 22, 2006 | 04:02 PM
jarrettdad's Avatar
jarrettdad
How about any of the Eastwood products?
Old Aug 22, 2006 | 04:36 PM
coda618's Avatar
coda618
Read good things about the eastwood encapsualtor, but I have not tried it. Por 15 has worked well for me though.
Old Aug 22, 2006 | 06:25 PM
jarrettdad's Avatar
jarrettdad
I have found some in NPD catalog, anywhere I can get it cheaper than $104/gal? How much will it take to do my undercarriage?
How about body panels? Just use some self etching primer in a spray can? Or would my paint guy have to remove that?
Old Aug 23, 2006 | 06:18 PM
jarrettdad's Avatar
jarrettdad
Bump for above questions......
