greasing ball joints, control arms, etc.....
Old Aug 23, 2006 | 09:19 PM
redstallion's Avatar
redstallion
Default greasing ball joints, control arms, etc.....
Some of you may recall that i am in the process of replacing damn near everything in my front end.
Now that i am reassembling one side, i need to know what is the proper procedure for greasing the new ball joints and upper control arm shafts. I don't think anything has any grease it it now. Is it possible to put too much grease in? And is there some "special" grease i should be using.
Thanks.
Old Aug 23, 2006 | 09:21 PM
Twister's Avatar
Twister
Default RE: greasing ball joints, control arms, etc.....
get grease from a good auto parts store, and just add it until it is full...
Old Aug 23, 2006 | 10:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
There is no such thing as too much grease on ball joints. If you don't have zerks on the control arm, now is a good time to put them in.
Old Aug 23, 2006 | 11:40 PM
Scott H.'s Avatar
Scott H.
Make sure the grease is chassis grease (it is short fiber, unlike wheel bearing grease that is long fiber). It should say "EP" on the tube (which stands for Extreme Pressure). Wipe off the zerk fitting so it looks like it's never been touched. Wipe off the excess from the ball joint. After your first drive of 10-20 miles go back under and wipe them down again.
Old Aug 24, 2006 | 12:54 AM
redstallion
ORIGINAL: Soaring
yes my new control arms have the 90* grease fittings already installed on them. thanks for the quick responses guys.
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
