Front Tire Size?
Old Aug 24, 2006 | 01:15 PM
BlackFlame's Avatar
BlackFlame
Default Front Tire Size?
Doing up Torq Thrust 2's on the 68 Coupe--what size tires for the front does everyone think?? 205's or 215's ??? Its mainly a sunday driver. Im planning on 255's in the rear, if that makes a difference--All of these are on 17" rims too---which size would look best? --- Opinions please---
Old Aug 24, 2006 | 01:19 PM
P Zero's Avatar
P Zero
Default RE: Front Tire Size?
225's for the front and 255's for the rear. Just my .02
-P.
Old Aug 24, 2006 | 01:26 PM
dodgestang's Avatar
dodgestang
17x ? and what backspacing?
Old Aug 24, 2006 | 03:24 PM
BlackFlame's Avatar
BlackFlame
17x7s with 4" backspacing should have said--sorry
Old Aug 24, 2006 | 03:51 PM
65mojoe's Avatar
65mojoe
http://www.mustangsplus.com/Merchant...Code=05281_set
I would go with 17x8's with the 4 3/4" bs. Run a 225 or 235 on the front and either a 245 or 255 on the back. With the 8" rim, your sidewalls won't buldge as bad with the bigger 255 tire as they would on a 7" rim.
Old Aug 24, 2006 | 04:09 PM
restomod66's Avatar
restomod66
Mojoe,
What size tires are you running on your pony? Also quick ? increasing backspacing moves the tire inboard closer to the suspension true?
Old Aug 24, 2006 | 04:49 PM
dodgestang's Avatar
dodgestang
ORIGINAL: BlackFlame
If you have the wheels already, the 215 should work out ok for you.
If you are buying wheels, mojoe is correct in pointing out that you 'could' put a wider rim if you wanted to and then also run a wider tire...if that is important to you.
FWIW too, if you want to run a 255 in the rear, I highly recommend an 8 inch rim.
Old Aug 24, 2006 | 04:53 PM
dodgestang's Avatar
dodgestang
ORIGINAL: restomod66
Yes, a higher BS moves the rim in closer to the suspension
Old Aug 24, 2006 | 07:52 PM
65mojoe's Avatar
65mojoe
Mojoe,
245/45 17 Yokohama AES100's on all 4
My torque thrust II's use the 4 3/4" BS
+1 to dodgestang's comment about the 255 tire and the 8" rim. Hopefully you haven't already purchased the 7" ones. Honestly, I would say go with a 245 in the back....visually its really hard to tell between a 245 and the 255 in terms of tread width and I think the 245's will fit better.
Old Aug 24, 2006 | 07:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 65mojoe
Mojoe,
Smart man.....I have often wondered why guys run different sized tires and wheels on the front and back. I guess they don't actually drive their cars on the highway, unless they have a spare for both the front and the rear.
