determining gears
Old Aug 25, 2006 | 03:46 AM
Sean W.'s Avatar
Sean W.
Default determining gears
hey fellas,
how can i find out what the gear ratio is on my 1968 stang?
Old Aug 25, 2006 | 04:16 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: determining gears
See if this helps.
http://science.howstuffworks.com/gear-ratio2.htm
Old Aug 25, 2006 | 06:30 AM
Sean W.'s Avatar
Sean W.
thanks for sharing, but it did not answer my question really... how to i find out what gear ratio my car is?
Old Aug 25, 2006 | 02:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
First of all, the rear end information is in your VIN, secondly, you should have a metal tag on your rear end with numbers on it, and thirdly, if you dont have either of those jack up the car, mark a line on the rear tire it does not matter which side, then make a mark on the driveshaft, rotate the tire one full turn while counting how many times the driveshaft goes around. Yours will probably turn about 3 times, making your rear either a 2.80 or 3.0.
_________________
Old Aug 26, 2006 | 12:53 PM
stang6790's Avatar
stang6790
This will work if you have a posi rearend but if it is not a posi you need to jack up only one wheel leaving the other on the ground (you could also jack up both wheels and have someone hold one of them) then follow the same procedure except when you get the number of rotations of the driveshaft you then multiply by 2.
ORIGINAL: Soaring
_________________
Old Aug 26, 2006 | 07:11 PM
paladin_1888's Avatar
paladin_1888
Multiply by 2??????????????
Old Aug 26, 2006 | 07:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
I think someone is misinformed.
Old Aug 26, 2006 | 07:41 PM
Cannonball888's Avatar
Cannonball888
He meant multiplying by 2 then take half of that.
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
