Brake lights #@%&!!!!!!
Old Aug 25, 2006 | 06:46 PM
joejoe61's Avatar
joejoe61
Default Brake lights #@%&!!!!!!
I'm losing my mind, I've replace the entire tailight wiring harness, yet I still only have one brakelight and no turn signals, but both tailghts do work. any suggestions?
Old Aug 25, 2006 | 07:04 PM
moparmatt89's Avatar
moparmatt89
Default RE: Brake lights #@%&!!!!!!
I went through the same problem that you have, it is a pain. I replaced and messed around with wires for weeks. It turns out that the turn signal wiring harness was bad in the actualy steering column. Replace that harness and make sure to wire it correctly and you should be good to go!
Matt
Old Aug 25, 2006 | 11:22 PM
67t5ponycoupe's Avatar
67t5ponycoupe
+1
Old Aug 25, 2006 | 11:45 PM
Volcom66's Avatar
Volcom66
mabey a bad ground
Old Aug 26, 2006 | 02:28 AM
65Pony's Avatar
65Pony
Replace the switch in your steering column, I had the EXACT same problem as you and once I changed it out everything is working perfect now!
Old Oct 28, 2006 | 12:30 AM
joejoe61's Avatar
joejoe61
Just a short note,, A BIG thank you ,, the turn signal switch.................That was it!!!! Thanks again, Joe
Old Oct 28, 2006 | 08:40 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: joejoe61
Ain't it fun to get a problem fixed?
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
amandahchase
Sep 3, 2015 10:09 AM
