Brighter Lights on 1970
I do a lot of backroads driving and light on my 1970 are just not bright enough. Almost to the point on being nervous driving it . I constantly drive with brights on and have never been flashed. What's a good upgrade that won't break the bank?
See if this information will help.
http://www.midnightdsigns.com/james/headlights.htm
Thanks for the link - Looks pretty straightforward - have you tried it. I get a little nervous when it comes to wiring changes. How bout the halogen replacement - do they make much of a difference? Seen some on Ebay claiming to increase by 70%.
ORIGINAL: palerider
Beware of installing modern head lamps. I've heard where the newer lights cause problems because of the higher electrical draw and added heat. I'm not positive about this, just something I have heard. Could be an urban myth or a fact.
thats why you run them off of the batter through a relay so you don't burn up your switch i got some 90L/120H bulbs i am gunna use as soon as i get an alternator off of a 96 taurus and put it in my 67 then i will have a one wire ford alternaotr that only cost me bout $20
ORIGINAL: 67Sally
I'd believe it. The halogens are relatively new technology, when you replace the old with the new you should get a pretty huge difference. Halogens can be annoying to other drivers but we have them on my Dad's Audi and they have amazing visability....but then again, they turn with the car too
ORIGINAL: palerider
std old Mustang lights are joke, but with halogen (H4) lights you can get very good visibility. If you have only two lights like in classic Mustangs you need two H4 - lights. Corvettes and car with four lights you need two H4 - lights and two H7 lights.
This is what I'm going to use.. I installed a super white set of lights and have a set of GT style lights that are going in the grill. This link is what I will use to power all the new lights. I already have the wiring and the relays, should work great..
ORIGINAL: Soaring
