Winter storage
Old Sep 6, 2006 | 04:24 PM
  #31
Charlie1's Avatar
Charlie1
Default RE: Winter storage
All of which reminds me why I sold my boat and bought a classic mustang...no more fogging oil, pickling cylinders, blowing water out of the manifolds or heat exchangers, packing wheel bearings, draining lower units (or worse, draining it in the cold in Nov and forgetting to refill in the spring...yes, I did that in my old age...$1400 to rebuild a mercruiser outdrive...and my dad the trucker always preached to me about checking all fluids!). The mustang is so much easier to use, work on, and put away in the offseason. But that's my choice...doing both boats and classic cars is great if you have the time and energy.
Pammy does raise one other variable...to run the car every few weeks, you have to be able to get at it. Lots of storage places pack 'em in or lock 'em in. Cost is a factor, too; I pay $300 for the private stall instead of $150 to be stuffed into a pole barn.
ORIGINAL: Todd1919
What about fogging the engine?? I do this with my boat when I winterize it for the year. 2000 Larson with an in/out drive running a 305 chev. Every boat dealership will tell you when you winterize: you should fog the engine. This consistest of either pulling the spark plugs and spraying oil onto the cylinders, or running the engine and spraying a fogging solution straight into the carb for about 20 seconds, then shut engine off and do not run again untill the spring. This procedure is done to protect internal parts.
I was planning on doing this with my car as well, since this is the first winter that I will have owned it.
[IMG]local://upfiles/35973/6304F2EAD5134F259BD1E472432C205B.jpg[/IMG]
Old Sep 6, 2006 | 05:47 PM
  #32
Booster's Avatar
Booster
I ♥ Acer
Don't start it up and run it unless you're going to drive it at least 30 miles. Just letting it run will develop condensation inside the crank case and this will get to intenal parts and start rusting. Put the battery on a tender as said before, fill the tank as full as possible with the highest octane possible, and put a fuel stabilizer in it. Consider "fogging" the cylinders. Check with a boat shop to see how this is done.
baddog671
Jul 26, 2016 01:20 PM
01GTon18s
Oct 13, 2015 04:44 PM
GTJIM
Sep 23, 2015 09:59 AM
Art161
Sep 9, 2015 10:33 AM
aleit2013
Sep 4, 2015 11:58 AM
