Water Pump Question
Old Sep 11, 2006 | 02:38 AM
  #21
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Water Pump Question
i was gonna say get a water pump pulley for a 289 with a single groove it doesnt go as deep as the 302 pulley should resovle ur problem? i got mine from don barrys mustang for 25$ it was a used original
Old Sep 11, 2006 | 02:54 AM
  #22
Toddman0025's Avatar
Toddman0025
Can a 302 expert tell me if this is correct:
On a 302 the lower crank pulley holds 3 belts, one belt runs WP and Alt, one belt runs AC, and one belt runs PS ?
And would that be identical setup on a 289 ?
Old Sep 11, 2006 | 03:00 AM
  #23
Colorado_Mustang's Avatar
Colorado_Mustang
No, you'll burn up the bearings in the pump, the shaft will break, the pulley and belt will then fly of in some random direction, usually heading straight towards the most expensive object around.
ORIGINAL: Toddman0025
I wonder if I should just throw the PS pump back in there and have it spin the water pump but not have the PS pump hooked up to anything - is that even possible (run dry)?
Old Sep 11, 2006 | 03:01 AM
  #24
Toddman0025
hah that's what i figured but had to ask
Old Sep 11, 2006 | 03:02 AM
  #25
Toddman0025
well I figure if I get a 3-groove WP pulley of a 302 one of those grooves MUST line up, so I can go Alt --> WP --> Crank.
I hope...
Old Sep 11, 2006 | 03:04 AM
  #26
rmodel65's Avatar
rmodel65
Yukon Cornelius
depends on the setup on how many grooves they had goes along with the options list but the i got a 302 in my car with the 302 lower pulley and im running the single groove 289 pulley
Old Sep 11, 2006 | 03:06 AM
  #27
Colorado_Mustang
Back belt: Crank->WP->PS
Front belt (no AC): Crank->Alt
I think the front belt in a 3-groove is for AC.
Old Sep 11, 2006 | 03:10 AM
  #28
Toddman0025
wow this has turned into a real headache!
what do people normally do when they install the MS converter? cuz once that PS pump is gone nothing will drive the WP! they conveniently forget to tell you all this when you buy it ! [:@]
Old Sep 11, 2006 | 03:16 AM
  #29
Colorado_Mustang
I like power steering...so I'll be keeping mine. Just get a set of pulleys and you'll be good to go.
Old Sep 11, 2006 | 03:22 AM
  #30
Toddman0025
how hard is it to swap the crank pulley?
