roller cams.......
Old Sep 17, 2006 | 02:56 PM
atomsk680's Avatar
atomsk680
Default roller cams.......
........are alot more expensive!!!!
http://store.summitracing.com/partde...5&autoview=sku
ive been looking at that one, but its $413!!!!!!
Old Sep 17, 2006 | 04:25 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: roller cams.......
Considering I can get an entire valvetrain with valves for that much... And $100 less with no valves..
Old Sep 17, 2006 | 04:36 PM
atomsk680's Avatar
atomsk680
anyone know where i can get a good roller cam that wont cost me an arm for?
Old Sep 17, 2006 | 04:40 PM
THUMPIN455's Avatar
THUMPIN455
sure buy a 87-95 5.0 and it will have a roller cam in it.. The heads are the holdup on those..
Check on Solid rollers, they are a bit cheaper than a hydrualic roller is.
Old Sep 17, 2006 | 04:41 PM
atomsk680's Avatar
atomsk680
ORIGINAL: THUMPIN455
thanks, will do on the solid rollers
Old Sep 17, 2006 | 04:44 PM
randy78045's Avatar
randy78045
Unless you like adjusting valves all the time, go hydrualic in my opinion...
Old Sep 17, 2006 | 09:00 PM
69mach1377's Avatar
69mach1377
ORIGINAL: atomsk680
This might not even include what is required to make your non-roller block work. I'd estimate $750 all said and done.
Old Sep 17, 2006 | 09:09 PM
THUMPIN455's Avatar
THUMPIN455
in the old days, especially on Chevy, valves had to be adjusted often. Now with polylocks, modern machining, and better tech valvetrain parts, including stud girdles, you dont need to adjust them every week. I ran a solid in one of my cars for three years and only adjusted the valves twice. Each time they were still spot on but I redid them anyway.
Old Sep 17, 2006 | 11:21 PM
slickman's Avatar
slickman
I agree, if I had to do it over again the only thing I would change in the build I just finished would be to go with a roller cam. It's the only thing I did not go the gusto on. In hindsight I should have, not that what I have is not good, just the roller would have been better. I did go with the roller rockers...
Old Sep 17, 2006 | 11:24 PM
atomsk680's Avatar
atomsk680
ORIGINAL: 69mach1377
ORIGINAL: atomsk680
yea i knwo, that is Just for the Camshaft
uedlose
Sep 30, 2015 08:01 AM
Tyoung68
Aug 25, 2015 04:31 AM
WDScott
Aug 17, 2015 06:38 AM
johnc
Dec 28, 2003 12:29 PM
92notch50Liter
Feb 18, 2003 11:52 PM
