1 inch spacer
Old Sep 18, 2006 | 05:44 AM
Volcom66's Avatar
Volcom66
Default 1 inch spacer
will a one inch carb spacer do much?
Old Sep 18, 2006 | 02:07 PM
65mojoe's Avatar
65mojoe
Default RE: 1 inch spacer
The phenolic ones absorb a lot of heat between the carb and manifold, but other than that I didn't notice any performance gain/loss when I switched from a 1" to my 5/8" nitrous spacer.
Old Sep 18, 2006 | 02:12 PM
Derf00's Avatar
Derf00
Gentleman's Relish
If you don't have a spacer, adding a spacer will make it idle a little smoother.
As stated, not only will the spacer insulate the carb from the heat which can cause vapor lock and lower density air, it allows the air/fuel mixture to atomize a little better since there's a bit more distance.
Old Sep 18, 2006 | 02:21 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
and depending on which once you get they do different things
Old Sep 18, 2006 | 03:06 PM
slickman's Avatar
slickman
These are suppose to help give you a little more on the bottom end depending on you're setup. However with that said, if you have a near perfect match with all you're components (like the heads, cam, crank, carb and so on) the deference will be negligible.
Thunderball
15
Nov 22, 2015 11:49 PM
jrrhd73must
Oct 2, 2015 09:17 PM
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Sep 28, 2015 05:45 AM
