MSD!!!
Old Sep 20, 2006 | 03:48 PM
slickman's Avatar
slickman
Default RE: MSD!!!
Yes, that's true. Then all you need is an MSD blaster coil...
Old Sep 20, 2006 | 03:55 PM
ADRIAN1's Avatar
ADRIAN1
Default RE: MSD!!!
ok well now im really interested in the ready to run deal.
Old Sep 20, 2006 | 03:57 PM
slickman's Avatar
slickman
Default RE: MSD!!!
Yes, that's the guy I got mine from.... You can't beat that deal anyplace!
ORIGINAL: ADRIAN1
Old Sep 20, 2006 | 03:58 PM
ADRIAN1's Avatar
ADRIAN1
Default RE: MSD!!!
did you use the blaster 2 or 3?
Old Sep 20, 2006 | 04:00 PM
slickman's Avatar
slickman
Default RE: MSD!!!
Blaster 2
Old Sep 20, 2006 | 04:02 PM
ADRIAN1's Avatar
ADRIAN1
Default RE: MSD!!!
why's that? wouldnt the 3 work better? idk, im just asking??
Old Sep 20, 2006 | 04:07 PM
slickman's Avatar
slickman
Default RE: MSD!!!
The Blaster 3 is the same as the Blaster 2 with the exception of the coil wire attachment, it helps with spark isolation. I never had an issue with that so, I did not spend the extra $10..
Old Sep 20, 2006 | 04:08 PM
ADRIAN1's Avatar
ADRIAN1
Default RE: MSD!!!
good to know...
Old Sep 20, 2006 | 04:25 PM
ADRIAN1's Avatar
ADRIAN1
Default RE: MSD!!!
how about your spark plug wire. which ones did you use??
Old Sep 20, 2006 | 04:27 PM
slickman's Avatar
slickman
Default RE: MSD!!!
MSD custom which means you cut them to size... With the wire loops I have I had to do that in order to get a clean look.
