289 parts for 200ci
Old Sep 20, 2006 | 03:33 AM
65andonly18's Avatar
65andonly18
Default 289 parts for 200ci
Was thinking about is it possible to put a bigger fuel pump,water pump, bigger brake cylinder, radiator, fan, etc on a 200ci wierd question it might make no sence but basically wondering if any 289 parts can go on a 200 car.
Old Sep 20, 2006 | 03:40 AM
Twister's Avatar
Twister
Default RE: 289 parts for 200ci
Here is a compleate list of interchangeable engine parts
oil filter
oil preasure sending unit
Old Sep 20, 2006 | 03:41 AM
Scott H.'s Avatar
Scott H.
engine specific parts, no. The fan and radiator will work. The Brake MC is the same.
Sounds like you have access to a V8 parts car, and you own a 6 cylinder car.
There are lots of other things you can use off the V8 car like suspension, steering, rear end, Brakes, etc.
My motto is get every thing you possibly can. You can always toss out or sell what you don't use.
Depending on just how much you can get, you may be able to convert your 6 cylinder car over to a V8 car.
Good luck,
Old Sep 20, 2006 | 03:44 AM
Twister's Avatar
Twister
ORIGINAL: 65andonly18
fuel pump....pump lever is backwards...
water pump is wider
master cylinder is the same
radiator...other than the pipe diameter for the hoses, the same
fan, same number of blades
Old Sep 20, 2006 | 08:28 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ditch your 200 and get a 300 they are mighty cheap in junkyards and you can even get a fi setup on it really easy
Old Sep 20, 2006 | 03:38 PM
Decurion's Avatar
Decurion
what?! factory rated at about 150 hp, done revving by 4500, heavy, and long. sounds like a great engine for a mustang. :thumbsdown:
ORIGINAL: Brandontyler65
uberstang1
Dec 7, 2017 07:10 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
kartracing87
Sep 28, 2015 11:01 PM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
