gears
Old Sep 22, 2006 | 02:19 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: gears
I would go with a B&M Shift Improver kit or the TCI equivalent.
Old Sep 22, 2006 | 03:20 AM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: gears
ORIGINAL: atomsk680
im probaby going to keep my stock gears at 3.00
even though alot of you wouldnt but, i get off the line just fine with my stock gears.
Great calculator THumpin.
I had 3.00 in my 8", bent the axles and blew the diff. Then borrowed a set of 3.20's while i got together a more bullet proof setup.
I ended up with a 31 spline 9", billet axles with 3.5's in it at the suggestion of my engine builder. It fries tires off the line into 3rd and jumps from 65 to 90mph in no time when I want to pass a truck. Great fun, but fuel consumption is s**t and it's revving too hard at 75 which is normal speed for me. It dropped my top speed by 20mph.
doing it again, i would agree with atomsk, because if the motor is any good, your 1/4mile times are about the same because there is one less gear change. But i'd also seriously consider the 3.2 as that was a good compromise...felt faster, but 300 less revs at highway speed.
Old Sep 22, 2006 | 03:22 AM
atomsk680's Avatar
atomsk680
Default RE: gears
well, maybe if i had a 289 i would feel differently though
but a posi rear with stock gears should hold up just fine to my clevo
Old Sep 22, 2006 | 03:42 AM
whoafrdofdapolce's Avatar
whoafrdofdapolce
Default RE: gears
if your planing on upgradeing to a 5 speed someday i would save your money and not get a shift kit. i would gear 3.73s with a 5 speed.
Old Sep 22, 2006 | 04:12 AM
ADRIAN1's Avatar
ADRIAN1
Default RE: gears
im planning to keep it auto. but want to add a shift kit. does anyone know where to get one?
Old Sep 22, 2006 | 04:36 AM
Cannonball888's Avatar
Cannonball888
Default RE: gears
ORIGINAL: whoafrdofdapolce
I just had a 3.70 put in. I have a T5 but I've still heard from some people that I still should have went 3.55. Anyhow, it's not out of the shop yet so I don't know how it will run. I'll post later.
Old Sep 22, 2006 | 04:46 AM
65mojoe's Avatar
65mojoe
Default RE: gears
emperor...the 8.8's came in the foxy body mustangs...the classics just had straight 8" rear ends.
Adrian, go with a B&M Shift kit for your C4....I have one in mine and it makes a world of a difference. Hard, positive shifts and it rides out the rpms a little more. Also I like shifting on my own too even when I am cruisin around town, and the shift kit helps with that. I would also recommend an aftermarket shifter too, either a ratchet style or a gate shifter...that way if you are shifting you wont accidentally jump into N, or worse...Rev.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
