Rocker nut question
Hey, So my last post I said there was a knock and ticking. So I took off the valve covers and found both nuts on the rocker arms were loose. So I tightened them up an started the engine. Wow...it ran so well for 2 minutes. Then the ticking came back. I took off the valve covers to find that one of the rocker nuts (the one that was really loose last time) was loose again!!
How do I stop the nut from backing off?
I took a look at some of the other nuts, and I think that someone took a punch and a hammer to them. It that what you are supposed to do? After you set the valves, use a punch and hammer?
treesloth
Sep 28, 2015 07:03 AM
