69 351w valves
Old Sep 22, 2006 | 07:27 AM
andykbob's Avatar
andykbob
Default 69 351w valves
Does anybody know what the clearance on a 69 351 W, between the rocker arm roller and valve when setting the valves?
Old Sep 24, 2006 | 05:02 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 69 351w valves
69 351W factory should be hydraulic. So, there will be zero lash. Factory arms torque to around 20lb-ft. Adjustable rockers tighten to zero last, then down 1/2 turn into the piston in the lifter (basically, you want to push the lifter piston just less than 1/2 way in it's stroke).
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
guitarman376
Sep 30, 2015 05:54 PM
lmurf60
Sep 24, 2015 10:07 PM
