Where to find this part??? PS bracket?
I need a power steering bracket/and bushings that bolts to the bottom of the car-the power steering arm mounts on to it-It is for a 66 mustang 289.Any help is appreciated.Thanks Scott
ORIGINAL: sixtysix
Like this? http://johnsmustang.com/Catalog/2055/
no thats not it-maybe I have the name wrong-this is a small 4x3 inch rectangle(I am guessing the size-I havent crawled under the car for a couple days now) that bolts onto the chassis.Thanks anyway. Scott
ORIGINAL: sixtysix
Like this? http://johnsmustang.com/Catalog/627/
Thats not it either-I think it connects the power sterring slave-that last piece might be on the other side of the slave-this piece sits under the driver seat on the chassis-I need to crawl under the car and look again-Thanks scott
If you are speaking of the bracket that bolts to the frame on the drivers side for the power steering piston shaft to mount to that should be easy
It will be the same on all Ford products with linkage type steering ever made.
It is also easy to make for your self
Good Luck
Good Luck
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Sep 1, 2015 08:16 PM
