Clutch Linkage Conversion
Old Sep 28, 2006 | 10:25 PM
hutchamatic's Avatar
hutchamatic
Default RE: Clutch Linkage Conversion
I can sell you a hyd clutch setup for the 4 or 5 speed. It is about $440 for the 5 speed and I would have to check on the four speed. Let me know. I would also install roller bearings on the clutch pedal.
Old Sep 28, 2006 | 11:16 PM
Scott H.'s Avatar
Scott H.
You can make your own kit for about $200.00. using the same parts as the kit. and fabricating your own bracket. This stuff isn't rocket science.
Here's the master cylinder
http://cncbrakes.com/cncbrakes.com-a...711&subseries=
Here's the slave cylinder
http://cncbrakes.com/cncbrakes.com-a...305&subseries=
Here's the clutch line
http://www.racerpartswholesale.com/long47.htm
The reservior for a Mid 80s chevy (like a S10) will work fine.
Or you could buy a blinging billet aluminum one if you want to spend some bucks.
Old Oct 1, 2006 | 01:40 AM
Scott H.'s Avatar
Scott H.
Here is a write up done by a guy who put a hydraulic clutch in his '68. this went with a T5, so the bracket you fabricate would be a little different. The nice part is he shows how to modify the clutch pedal. Just fabricate a bracket to hold the slave cylinder that bolts to the upper and lower transmission mounting flanges. I would not use a metal line off the slave cylinder. Instead run the braded hose all the way to the slave cylinder. There is too much vibration. Eventually the line will either crack or loosen, as it has no support. Other than that, it's a decent install.
http://home.comcast.net/~grabblue65/Hyd_Clutch.pdf
Good luck,
Scott
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
