posi
Old Sep 27, 2006 | 03:25 PM
espskillz's Avatar
espskillz
Default posi
hey i have a 289 and when taking off it has way to much power for just one wheel spinning .. would it be hard to change it to posi and how much would it cost me? if anyone has done it before.
Old Sep 27, 2006 | 03:36 PM
65mojoe's Avatar
65mojoe
Default RE: posi
cost me 350 bucks shipped for a complete pumpkin with a locker unit and my choice of motive gears (3.55's). IF you've never done a rear end before, I would recommend takin it to a shop (which will probably cost you another hour or two worth of labor) to have it installed.
Old Sep 27, 2006 | 04:10 PM
moparmatt89's Avatar
moparmatt89
Default RE: posi
hey,
Where did you get that for $350?
Old Sep 27, 2006 | 04:14 PM
shr's Avatar
shr
Default RE: posi
really i cant find one that cheap either so......give it up where you get it at?
Old Sep 27, 2006 | 04:35 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: posi
ditto
Old Sep 27, 2006 | 04:45 PM
Rorin67's Avatar
Rorin67
Default RE: posi
ORIGINAL: espskillz
...would it be hard to change it to posi ...
Is it proper to call a locking "FORD" differential a "posi"? I thought that was GM's trademarked term, and that Ford uses the terms "Detroit-Locker", "Traction-Lock", etc.
Am I losing my mind?
Old Sep 27, 2006 | 04:47 PM
Corrodiate's Avatar
Corrodiate
Default RE: posi
Posi is just easier to say, and it sounds cooler.
Old Sep 27, 2006 | 05:35 PM
deadcarnahans's Avatar
deadcarnahans
Default RE: posi
ORIGINAL: Corrodiate
It doesn't sound cooler. This is a chevey term and shouldn't be used on a Ford.
Old Sep 27, 2006 | 05:47 PM
Justin66GT's Avatar
Justin66GT
Default RE: posi
Best non-trademarked term to use is "limited slip differential".
It's pretty darned easy to slide the axles out and replace the pumpkin.
I have a Detroit Locker in my 9". If I drove it on the street more I'd probably want the new Truetrac (smoother gear action, compared to the Locker that ratchets).
Justin
Old Sep 27, 2006 | 06:40 PM
65mojoe's Avatar
65mojoe
Default RE: posi
MAE Racing
This is where I got my pumpkin from, although I don't see any available 8" on there site currently. Give them a call though, I believe they manufacture their own reinforced 8" housings and they can pretty much custom build a 3rd member any way you want it.
EDIT: Here is an 8" center section : 8" Posi. WOW, prices went up! I bought mine from these guys' ebay store about 3 years ago.
