tach question
Old Sep 27, 2006 | 10:52 PM
andykbob's Avatar
andykbob
Default tach question
I have a 69 351 fastback and I was wondering where I hook up the tach lead? Does it go tp the distributer?
Old Sep 27, 2006 | 11:02 PM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: tach question
Ones going to go to the coil and ones going to go to ground
Old Sep 28, 2006 | 04:08 AM
Volcom66's Avatar
Volcom66
usually all tach wires are the same color... so red goes to ignition power, white goes to dash lighting, black goes to battery ground, and green to (-) side of coil. if you have msd or electonic ignition you run green to the tach output on the box.
Old Sep 28, 2006 | 05:06 AM
Sean W.'s Avatar
Sean W.
Whats a tach?
Old Sep 28, 2006 | 06:46 AM
Volcom66's Avatar
Volcom66
A "TACH" is just short for Tachometer. its the gauge that tells you the engine's RPM. if you have an auto there is really no reason for one but if its a manual you want to have one to see where the best shift point is. Im sure someone else on can give you a better understanding.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
