Which comes first
Old Oct 1, 2006 | 07:52 PM
green_blurr's Avatar
green_blurr
Default Which comes first
I recently back up with my drivers side door and um well its not pretty after crying about it i decided it would be a good time to body and fender the whole car and paint it im curious do i sandblast the car first? then remove the body parts or the other way around
[IMG]local://upfiles/43944/D274C06CEEE744669251ED962C8BD0EC.jpg[/IMG]
Old Oct 1, 2006 | 07:55 PM
restomod66's Avatar
restomod66
Default RE: Which comes first
I have a 65 fstback being done and the body parts on the front end have been removed so we are going to paint before reassembly.
Old Oct 1, 2006 | 07:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
It's easier to blast the fenders, hood, doors and trunk lid with them off the car. I would suggest that you use another media other than sand if you are a novice at blasting paint off car parts. Sand can warp parts fairly easily if you haven't learned the proper technique.
Old Oct 1, 2006 | 11:22 PM
THUMPIN455's Avatar
THUMPIN455
Also you need a HUGE area to do it.. outside is much better than inside unless you like media all over everything. I prefer chem stripping or regular sanding to blasting of exterior body panels. Too easy to warp them from the heat. Chem should be done outside too.. well ventilated area is MANDATORY. Water is too..
I sandblast the underside of the car, floor, firewall framerails, nooks and crevices where I cant get with a DA sander. Doorjambs are easier with a blaster, but sand down the door skins. you can really mess up sheetmetal by stripping it inccorectly.. Have pics of what incorrect will do to it if you like..
