Door panel ?'s.
Old Oct 5, 2006 | 03:36 AM
badazz68stang's Avatar
badazz68stang
Default Door panel ?'s.
I was wanting to paint the upper and bottom part of the inner door panel the same color as the car. The top n bottom have that textured surface, so should i paint over that? or is there some way to strip those off and paint the metal below them. '68 coupe.
Old Oct 5, 2006 | 10:45 AM
paddy187's Avatar
paddy187
Default RE: Door panel ?'s.
i thought the texture was metal is in early stangs and most people want to keep!! but a bit of sanding a few paint coats should see to it
Old Oct 5, 2006 | 11:47 AM
Soaring's Avatar
Soaring
I ♥ Acer
You want to keep that texture, so only use a chemical stripper. The texture is part of the metal, and sandpaper will smooth it out.
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
