1966 ignition switch trouble
Old Oct 7, 2006 | 10:12 PM
YNOT 66's Avatar
YNOT 66
Default 1966 ignition switch trouble
Haveing trouble removing the switch assembly any hints would be appreciated...
Old Oct 7, 2006 | 11:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 1966 ignition switch trouble
Use the key, and turn the ignition to the acc side. Take a paper clip and insert into the little hole then it will pop out.
Old Oct 8, 2006 | 02:25 PM
Ste7of1's Avatar
Ste7of1
What Soaring said removes the key insert which is the most common part of ignition switch replacement, but, if your problem is the switch itself, then continue by removing the nut on the backside which holds aux wiring in place then remove the wire harness. finally, the switch itself is held in place by a thin metal cup and spring mechanism wich needs to be pushed in and rotated to pop it off. It's tough fitting your hand in behind the dash, but keep at it and it will pop loose. Putting it back (replacement) is just the opposite, but, also sometimes tricky just because of the tight space.
lincolnshibuya
Jul 5, 2020 03:05 AM
CS2007
Jun 25, 2019 09:45 PM
bradleyb
Nov 27, 2015 07:50 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
