distributor removal
Old Oct 8, 2006 | 03:11 AM
atomsk680's Avatar
atomsk680
Default distributor removal
ok, i dont want to screw up, how do you remove the distributor?
Old Oct 8, 2006 | 03:16 AM
BakoLuke's Avatar
BakoLuke
Default RE: distributor removal
on my I6 i just unbolted it and then pulled it out...its getting it back in thats the hard part
Old Oct 8, 2006 | 03:21 AM
atomsk680's Avatar
atomsk680
yea my dad said i need to crank the engine back to starting position after i put in my new cam and intake
Old Oct 8, 2006 | 03:26 AM
BakoLuke's Avatar
BakoLuke
yeah...you have to put it in "top dead center" it should be marked on your timing chain cover and on your harmonic balancer...but sometimes it harder than that
Old Oct 8, 2006 | 07:23 AM
Volcom66's Avatar
Volcom66
yeah taking it out is easy putting it back in is hard. make sure at TDC and not 180 off. I would stongly suggest a dizzy tool
Old Oct 8, 2006 | 11:23 AM
1965MustangFastback's Avatar
1965MustangFastback
If you're not replacing the dizzy all you need to do is take the cap off and mark where the rotor is pointing too, if the dizzy has vacuum advance mark where that's pointing at also.
If you're replacing the dizzy, just unbolt and remove! But when you're installing a new dizzy you'll need to be at TDC on compression stroke! A little tip when marking the location of the rotor and the vacuum advance use a piece of masking tape and a maker! Look at my photo and you'll see the tape with the marker lines on it.
[IMG]local://upfiles/16936/2E4B9D6CDE7746529904C46FA2F88650.jpg[/IMG]
Old Oct 8, 2006 | 01:07 PM
atomsk680's Avatar
atomsk680
k thanks!
Old Oct 8, 2006 | 01:29 PM
6mustang6's Avatar
6mustang6
If the number one cylinder is at the top of the piston, thats top dead center right? IS there anyway to screw that up?
Old Oct 8, 2006 | 01:31 PM
burnettt's Avatar
burnettt
be careful not to pull out the shaft that spins the oil pump
Old Oct 8, 2006 | 01:50 PM
428coupe's Avatar
428coupe
ORIGINAL: 6mustang6
The number one cylinder gets to TDC twice in the 4 stroke engine, once is TDC on the compression stroke and once is TDC on the exhaust stroke, the camshaft rotates twice for each rotation of the crank. If he installs the distributer with the rotor button pointing at the number one cylinder while the number one cylinder is at TDC of the exhaust stroke, the camshaft will be 180 degrees out.
