HELP!
Old Oct 9, 2006 | 02:59 PM
68coupe's Avatar
68coupe
Default HELP!
dear all
i am having a bitch of a time figuring this problem out...
at idle in 'drive' (stop lights, etc.) my '68 will actually stumble and TURN COMPLETLEY OFF. i put it back in park and it fires right back up. if i keep it in neutral while its idling, i can sometimes feel it stumble, but it doesnt switch off.
today, cruising at about 40, i felt it miss pretty bad, but it kept running. generally, once it's going it runs fine. its only at idle its got the problems.
i have the ignitor II module instaled on the stock dist., a 500cfm edelbrock and intake and headers...pretty much everything else is stock...please help me...im in the process of saving for a new motor/trans and the LAST thing i need is to put more money into the pokey 289. thanks in advance, everybody.
Old Oct 9, 2006 | 05:39 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: HELP!
What's your idle speed? When was the last time your engine had a tune up?
Old Oct 9, 2006 | 07:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: HELP!
ORIGINAL: Colorado_Mustang
Bingo Colorado. Sounds like you just need a general overall tune-up.
Old Oct 9, 2006 | 08:36 PM
Sean W.'s Avatar
Sean W.
Default RE: HELP!
+1 also check your ideling speed, might be a little slow.
Old Oct 10, 2006 | 02:09 AM
LoganCL's Avatar
LoganCL
Default RE: HELP!
i have that problem with my 65. the problem for me is that when the exhaust was changed that was compensated for... i just need some sensor now... il get that soon enough lol. mine rarely shuts off though... probly done it 3-4 times.... its stumbles at long lights though, but when im going its great.
Old Oct 10, 2006 | 05:26 AM
andrewmp6's Avatar
andrewmp6
Default RE: HELP!
fast fix is adjusting the idle on the carb but you might need a tune up like they said
